Originally Posted by Tim Taylor
Roughly, I lost 11 lbs with the Larini, 9 lbs with FF header and cat, 21 to 22 lbs over stock wheels with RAC's, a lb or two with CF diffuser, totalling about 44 lbs, then you have to add back for the BWR SC set up (which I am guessing adds about 15 - 20 lbs net, and a couple of lbs per back tire to go to the 245/40/17 tires so summing it all up I guess about a 20 lbs net loss.
Don't forget to add the black vinyl around the air intakes though - at least 1-2 grams per side!
Planning at swapping out the battery? That's like another 10-20 lbs right there, depending on which one you choose...
Again, sweet car.
