Originally Posted by 25psi_Elise_Killer
SOW is a 3-4gear track primarily. You can probably hit 100ish MPH on the main straightaway before it goes into a long sweeper turn if you're running clockwise. Much faster than auto-x.
Fast autox. At El Toro we can easily run a 90mph autocross. BUt speeds in a straight line don't change the speeds in turns.
Most of the turns at SOW are no faster than the speeds we hit Sunday. To compare, some of the corners at Buttonwillow and Willow Springs are over 100mph.
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
..is a stranger in an open car. Tempt you in and drive you far away
