05-12-2008, 04:08 PM
#24 (permalink)
Third Eye Open
Originally Posted by mpsalm
You're totally right. I should have done it at 3am instead of 2am when I actually did it.
So by your logic your run was safer with people driving home from the bars!'
Not sure where you're from but if you can find an empty passage into Manhattan at any time of day you're a better man than I.
Keep Digging, your not going to convince many people that going 100 MPH in the Lincoln Tunnel is safer!
Also if you can lose control of a car going in a straight line starting at 40 miles an hour, you should stick to walking.
You weren't going 40 MPH you were well beyond the posted speed limit Unless they changed it to 100 MPH and probably scared the crap out of the vehicles you passed
So you equate hitting someone going the same direction as you in a straight line with coming around a blind turn on a windy road with 2 way traffic?
Both can have devastating outcomes, If I remember correctly a certain member of the Royal Family (Princess Diana) died in an Accident in a tunnel at excessive speed! and last time I checked, Hitting someone in any direction was bad!
Care to re-examine your logic there?
Do you care to re-examine your logic as well?
The point I am trying to make is that your comments were unjustified as the videos I have posted or watched of Ronin, there are rarely ever other cars in them for a reason, Ronin doesn't want to wad up his car or anybody elses for that matter and your false sense of security in your abilities and equipment can fail you when you least expect it. I had a tire failure going just over 100 MPH in a straight line and I am lucky to be alive just an FYI!
Bone Stock
