Old 05-12-2008, 08:31 PM   #29 (permalink)
uglyduck
uglyduck's Avatar
Does the system also come with a fan for the front mounted heat exchanger? From what I understand they have to run the coolant tubes through the frame from the IC to the heat exchanger. Are you concerned with heat buildup in the side frame? as it is they can get pretty worm as they house the rad as well as oil cooler lines. This will likely add a few gallons of coolant? Is there an expansion tank in the system or just the overflow bottle attached to the rad cap on the top of the IC?
I can't wait to see the finished product......keep it coming.
2006 Tripoint SC with 10psi pulley and Aquamist, custom 2.5" free flowexhaust, FF headers, Decat, Ohlin's, track brace, custom carbon bits
1994 Caterham 7, R400 zetec conversion in progress
uglyduck is offline   Reply With Quote
