Originally Posted by 2-Y-CHROMOSOMES
any updates phil?
Sure...
I had a weak idle and bit of popping that I needed to iron out... I ended up lowering the accell max bits to 15 from 25. That made all the difference in the world. The car now idles better than with the katana and it comes off idle perfectly. Gear exchanges are also super smooth now. That one change fixed the car to where it's very drivable... almost trackable- but not quite...
I'd like to see some more maps that folks are using to get a feel for where people are...
My cam transition (just at the switch) is a bit garbled. Not terrible, but it's not crisp. Any pointers to clean that up?
The wide band is nice since I can target particular AFRs and the ECU tunes to them with fuel trims... I'm still memorizing lambda for the AFR. It takes a while for the brain to convert lambda into useful info right now, but it will come in due time...
Thanks for asking.
Best,
Phil
