I had a change of plans... I was going to make a housing to mount the camera near the roof (so I can see my blindspots) but the multivex mirrors worked so well I decided to mount it on the intended location: the license plate.
I did make one mod: I added a switch and connected the power directly to camera, so I can use the camera as a rear view mirror to see directly behind me (instead of wiring to the backup light and only able to see behind me while backing up). I will post pictures later of the switch, but its basically a push on/push off switch from radio shack mounted to a bracket and secured using 3m double sided adhesive and the screw on the shifter console.
I was mostly impressed the night performance of the camera, it seems with a slight bit of light, it can make out details better then the side view mirrors. I was under the impression these cheap cameras would be useless at night. The headlights didn't totally wash out the camera, but you do see a white blob so you know a car is there.
the first pic is a night view with street light. (car is stationary but the quality is the same while moving)
the second pic is night view in total darkness with the backup light on.
Phantom Black 2007 Exige S221.56436. All options.
Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver
Facebook group: Add lightness...and Darkness!
