Old 05-14-2008, 06:23 AM   #7 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
A048 tires do not have a problem gripping wet pavement as long as the thickness of the water layer is so thin as to still allow conforming adhesion of the rubber around the road surface irregularities. As soon as the water layer is thicker than that you are at risk of hydroplaning. Under this condition, and of course depending on your speed, the A048 tires act like fat water skis and away you go.
xtn
