Help! How to remove harness bar in Exige S?
Hi folks
I'm installing my Kenwood sub/amp onto the rear panel today. I need to remove the rear panel to do so. Thus, I need to remove the harness bar.
The vBulletin forums never allow one to search for 3-letter words, so I cannot search for harness "bar". My searches have come up with nothing about this.
How do you remove the harness bar? I know I read somewhere that you unbolt both ends, slide it to one side (without hitting the clam) and then slide it out of the panel. Then the panel just comes right out after a few screws(hopefully).
The only bolt I find for the factory harness bar seems to be INSIDE the bar...each end of the bar has a "T". The bolt seems to be inside the "T", like this: (warning crude drawing approaching)
(rear)
-------------------| <---bolt in here, head is exposed at rear
How am I supposed to get to this bolt? I can't get a tool in there, unless I'm missing something. Is this the right bolt? Can I remove the speaker "shroud" to gain better access? This plastic "shroud" seems to be riveted in and not removable.
Thanks in advance. I'm mid-install and can't continue until I get this info. I'll keep tinkering but would have to have to put the seats back in and start over another day.
-Smoky
'07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1
