Old 05-18-2008, 03:51 PM   #3 (permalink)
biodan
Originally Posted by dma550 View Post
A few years back I was playing with fitting Porsche 944S2 calipers on my 550 spyder project. I investigated using the smaller rears on the front so they could clear a 15" wheel. One thing that may be a barrier is that sometimes rear calipers use different size pistons, where the leading piston is smaller diameter than the trailing piston to give a more progressive breaking feel. You don’t want this on the front of your elise, check the calipers for this IMO before you proceed.
I just checked the calipers since the AP kit is off the M3. The rear CP5144 caliper has equal sized pistons (4). However, the front CP5575 caliper is a 6-pot with the leading cylinder smaller than the others.
While i have not yet dismounted the stock 16" LSS rim, i did place the 5144 caliper up against the wheel. This caliper may even fit inside a 16" rim. However, it seems thicker than the stock caliper. Likely a different offset or spacers or even custom bracket would be needed but i'd have to check clearance on both sides with a proper rotor installed.
This is just rambling thoughts now, i have the AP Racing kit for sale but a buyer may only want to buy the fronts - in which case i would have an opportunity to experiment.
2005 Saffron Yellow Elise, Sport/Touring, VF Stg2, 2bular hdr/sport cat, Larini 8", Saikou CC, shifter mods, FF engine damper, ACT/Toda, AFR/oil temp gauges, RTV toelink, Moroso oil pan, AlumDiffuser, ABS splitter, FF spoiler, widened undertray, 5-pt harness, Odyssey battery, Multivex, BWR key
2002 Silver M3, SMG, Ground Control suspension, AP Racing BBK, RAC RS110s --sold--
biodan is offline   Reply With Quote
