Old 05-31-2008, 09:54 AM   #13 (permalink)
Scrumpot
Live on the edge
Scrumpot's Avatar
Dimming the guages on the '08
Okay Guys - for those of you still stuck on this one (as I was too!), and if you did a search (J/K - Just doing my Ace10 impression here! ) - you can see my previous post specifically on this subject HERE.
For your Brake Bed-In Procedure, I've attached a scan of that suppliment for you below.
As far as your #2:
2) There is a loose wire pair behind the battery, one green wire, one black, with a connector on the end (loose as in, not plugged into anything). I looked and could see no obvious mate. The tail lights all work, wiring appears complete (comparing left and right tail lights), and everything seems to work (well, except #1 above, but hard to imagine it could be related given the location). I've only traced the wire pair back to the engine compartment. Anyone know the story on this?
That is for your battery minder/charger accessory. My dealer (S&S) provided one to me with the car. Sounds like yours is pre-wired for it, and if not provided, I would still reccomend picking one up. These little batteries really hate to sit for any extended period of time without at least a trickle charge being applied to them, that this pre-wired accessory does for you.
Congrats again on the new car!
Hope this helps!
Cheers,
-Grant
'08 Exige-S Club Racer
Desnorkelled, Stage-2, HID's, DRL Defeat, Sector111 Tow-hook & Fire Extinguisher, Deeply Fettled Roof S/C Air Intake, Schroth Prof II ASM 4pt Harnesses
Scrumpot is online now   Reply With Quote
