Old 06-04-2008, 03:08 PM   #71 (permalink)
Thomasio
Internat'l Man of Mystery
Thomasio's Avatar
Originally Posted by xeeeejme View Post
I'd be curious how much of the difference is due to just heat soak on the dyno. For example, is that the difference of the averages of the dyno readings between the two setups? Or is that the difference between the first run of each setup on the dyno?
I imagine that the heat soak for the engine running on the dyno (especially for the non-rls intercooler) is greater than if you're on the street in normal driving or on the track with greater air flow. So would the real world/track gain be less than the 26 HP stated?
That difference only gets greater with heat soak, because the stock intercooler heat soaks far worse and far faster. Results will be posted as soon as I get the data, that will show the trends better than I can describe. It was impressive.
07 SY Exige S
really light stuff Intercooler . rls Tubes rls Water/Methanol Injection rls 3.1" Pulley rls Wing Plates .
Prototype Composites CF Roof . PC CF Front Spoiler .
Thomasio is online now   Reply With Quote
