You might try a couple of different things. Depends on the fitting.
1. Get an air cutter or machine shop : Cut the outer fitting off and shove the hose on the male tube and clamp it.
2. Cut a slit the length of the outer fitting (1/16") shove the hose inside and compress the outer fitting with a clamp until the slit joins together.
Get a good quality clamp --- might not be a bad idea to double clamp it.
