Old 06-23-2008, 09:11 AM   #18 (permalink)
dominus22
dominus22's Avatar
Smile How to bleed your brakes
First let me tell you that i have had experience using diferent vacuum and preassure bleeders and none of them work as good as the original way of doing things and that is pumping the brakes, now what i found with lotus is that it helps alot if you have the car runing, due to the abs hydraulic unit that is installed in the car sometimes air gets traped in the unit. With the car runing in a well ventilated area have some one help you pump the brakes 3-4 times and start bleeding from the right rear>>>left rear>>>front right>>>ending with the left front this should eliminate any problem with air in the system make sure you follow the sequence other wise you will only be pushing the air around the system and not bleeding it out
dominus22 is offline   Reply With Quote
