Another option I forgot to post was to loosen up the bolts that the muffler is hanging from. They used rods that go through rubber clamps and there is a lot of tension here too. This is probably the primary point of the bind from my analysis. Even with the ForcedFed engine damper installed, this engine still moves a lot. Without the damper installed the engine is really moving a lot more and that just magnifiies the entire problem with the exhaust even more.
2006 Diasio D962R Arancio Borealis
SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet"
