Old 07-07-2008, 10:20 PM   #103 (permalink)
PatrickShim
How you doin'?
PatrickShim's Avatar
[Service #9 Drop-off] July 7, 2008 - 18,689 documented miles
I dropped off the car today at Lotus Beverly Hills for the recurring Check-Engine Light issue. This time we will be replacing the entire wiring-harness.
I believe it is a major job. Allen and Stephen are taking the car apart...
Hopefully we'll get the all the issues resolved...
[Service #9 Pick-up] July 11, 2008 - 18,692 documented miles*
It was a major work (see the posts below).
All the wiring harnesses were replaced (hopefully this will take care of the recurring P0420 code), and since the car was in the service, we changed front brake pads as well.
All the services since new
[Warranty Service Items]
- ECU (replaced) - LBH
- catalyst/downpipe (replaced 2x) - LBH
- camshafts (replaced) - LBH
- O2 Sensors (replaced) - LBH
- exhaust (Stage-II cracks, replaced 2x) - SMC/LBH
- wiring harnesses - LBH <---------
- front/right turn-signal housing (replaced) - LBH
- A/C relay (replaced) - LBH
[Warranty Accessory/Part Items]
- soft-top bars (not supplied by dealer) - SMC
- blower motor resistor kit (update) - LBH <---------
[Undocumented-Warranty Items]
- front/right turn-signal bulb (replaced) - LBH
- loose handbrake lever (repaired) - LBH
- passenger-side window making wind-noise (repaired) - LBH
[Non-Warranty Items]
- oil changes w/ Mobil Delvac Synthetic 5W40 (@ around 1,000mi, 7,000mi, 12,000mi) - SMC
- oil changes w/ Havoline Synthetic 5W40 (@ around 17,000mi) - LBH
- rear tires Yokohama ADVAN A048 (replaced @ around 12,000mi, nail in tire and wear) - NE
- rear tires Yokohama ADVAN A048 (replaced @ around 17,000mi, nails in both tires) - LBH
- front brake pads (replaced @ around 18,000mi) - LBH <---------
(*LBH - Lotus Beverly Hills, *SMC - Symbolic Motor Cars, *NE - Newport European)
PatrickShim is online now   Reply With Quote
