Old 07-14-2008, 11:08 AM   #57 (permalink)
turbophil
Plug Whisperer
turbophil's Avatar
Images: 3
+1 on Jim's comments...
I'm quite certain that there's headers make power. The sound is clearly different.
The U bend is clearly not accurate. It doesn't come a full 180 degree back around and it's angled down too far. The jack and torch method I used only fixed the vertical aspect probelm of the bend and got me back on the road. Where Jim's cut and weld fixed both. I was hoping that I could deal with front to back issue since my exhaust is so small___ and I will *deal* with it in the short run. In the long run, I'm probably going to have to cut the U as Jim did to fix that issue. If anything, the exhaust can is sitting so catty-whompis that it just looks bad through the clamhinge rear panel
I don't also don't regret the purchase, as it is a nice piece in general and half or a third of the cost of others out there... However, it's clearly not bolt on product for the masses----yet. Weapon R or Dusty needs to make a change in the product to fit the car, as I doubt most will have the ability to do what Jim and I did...
Best,
Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |
See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08
If something ain't worth doing right, it ain't worth doing at all...
turbophil is online now   Reply With Quote
