Originally Posted by jim-clayton
I cut a 1" wide section out the u-bend. Dead center. Basically cut the tube on either side of the O2 bung. Used an upright belt sander to get the angle I needed and welded it back together. Installed a new O2 bung.
Phil heated his with a torch and jacked it into position. He's a better man then I !
It's possible that it might fit a small dia muffler. The angle of the u-bend pushed my can too far towards the rear of the car. Makes sense?
yup that makes sense. Did you guys use the solid brackets that hold the two pieces of the header together? I am using springs and hoping that might give me enough play.
