Originally Posted by Pestodude
Smoky, I love this idea, if it's doable. I'm having the Proalloy chargecooler installed (Sector 111 is using my car as the fitment test mule). I'm thinking, hmm, now I've got this scoop on the roof in cool air doing nothing. Maybe I can direct the flow into the airbox. Would it f up the fuel/ air ratio I wonder?
I don't see why it would. It's basically the same thing as placing a filter into a cold-air position (like AEM does with other cars). Except in our case one is bringing the cold air to the airbox, rather than placing the airbox (and an open element) into the air (such as a fenderwell).
No pressure change would occur. Just the air source. And any rain that would enter the scoop would get trapped on the sides of the ducting and evaporate long before it reaches the airbox entry.
The engine would get the same amount of air as before, just ambient temp air. The ECU is well able to adjust for air at ambient temps flowing past the MAF. That would not be a problem.
It would just a be a cleaner, cooler source of air. If anyone knows someone who could take the OEM hood scoop bellows and mod it or use it as a template to create a modded version, one that captures the scoop air and funnels it down to a port, then the next few steps (tubing/plumbing to the airbox) would be fairly straightforward.
Perhaps we could pool resources and make it happen. Test it on our cars. See if it makes a difference one way or the other.
apk the graphs are fantastic! Really clear data. Very, very cool to see someone going through with real data collection. You're a true Mythbuster!
Any chance of throwing in the non-cup roof (Exige S) into the data? Do you still have one available?
Thx for the great reporting!
