Nice work, 2 things I would add, first have a stainless heat sheild made to go between the IC and the engine to remove the heat soak from the engine, second the problem with making the roof scoop into the air filter duct will come about when you try to remove the old ducting from the clam, it is bonded on. I considered this after I fitted my charge cooler and then dropped it after fitted the Lotus Sport uprated airbox as I felt that mod would then have no benefit.
