Now that's a very interesting dataset. It appears that once you're at roughly 40mph or more that the post-cooler can get to and stay in the range of 102 plus or minus a couple degrees. So 15 degrees warmer than the presumably ambient pre-cooler air.
Except that presuming the pre-cooler air is ambient is probably a mistake, what with all the warm air coming off the radiator and flowing right up the windshield into the scoop.
xtn
