1) Tint all glass with “only” 3M Crystalline - Greatly reduced solar heat
2) Insulate side sills & front firewall on inside of the cockpit - Reduces convected heat from coolant, heater & oil pipes
3) Block the air inlets in the nose - Only use cooler re-circulated air
4) Open up the driver’s side foot well recirculation inlet - Increases air intake air volume & results in substantial increase in air flow through vents into cockpit.
5) Replace the evaporator, capillary tube thermostat with an electronic version - prevents evaporator freezing
Originally Posted by yellowlotus
can you point me towards some threads regarding ac modification?
