Originally Posted by TheViper
1) Tint all glass with “only” 3M Crystalline - Greatly reduced solar heat
2) Insulate side sills & front firewall on inside of the cockpit - Reduces convected heat from coolant, heater & oil pipes
3) Block the air inlets in the nose - Only use cooler re-circulated air
4) Open up the driver’s side foot well recirculation inlet - Increases air intake air volume & results in substantial increase in air flow through vents into cockpit.
5) Replace the evaporator, capillary tube thermostat with an electronic version - prevents evaporator freezing
6) Make sure that the coolant system is bled properly. Saved me 10 degrees of coolant temperature; coolant which circulates around the cabin. Add water wetter to the coolant. Your temp should be under 200 degrees most of the time. I live in Texas. The temp stays about 194.
7) Consider bypassing the heater core. You can cut and splice, or you can install a switchable system. Search for "heater bypass". Well worth doing.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
