Old 07-23-2008, 08:38 AM   #26 (permalink)
DPM
DPM's Avatar
The engine mounts should help a lot with taking stress off the exhaust. I have the ForcedFed engine damper and even with that, the torque from the turbo would sheer the bolts off that attach the turbo to the exhaust pipe.
My fix, which has worked very well to date, was to remove the catalytic converter and install a 3" braided flex pipe using v-clamps. Making it this way makes it easy to take it on and off if you need to have the CAT on for emissions testing, etc.
This modification has allowed an adequate amount of "give" on the exhaust. I also drilled out the 4 rubber mounts that the exhaust hangs on with a 1/2" drill bit, they were way too tight and would bind.
I'll post a pix this afternoon.
Also if you are concerned with getting a lot of the stored heat out of the rear of the car in the exhaust area, remove the left wheel well liner. It works great!
2006 Diasio D962R Arancio Borealis
SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet"
DPM is offline   Reply With Quote
