Originally Posted by turbophil
I'd seriously consider putting a duct on the drivers side c pillar and see if that helps. I think it would look pretty cool. You can't see both side of the car at the same time so whycare about symetry
Frank found that the mesh blocks a heck of lot of air on those side scoops, so I would certainly remove that jazz...
The reality is that you need a lot more air to really get some good efficiency out of those ICs and I think you've shown that the big issue is that little opening. If you can double the size of that hole, you'll probably double the air... If I were you, I'd start doubling
Best,
Phil
Agreed, the mesh on the side scoops is finer (i.e. blocks more airflow) than those on the radiator and hatch...
Also, and not surprisingly... the flow through the intercooler seems proportional to the smallest cross section in the ductwork... so doubling would be good...
My videos:
http://www.youtube.com/user/apk919
