Old 07-24-2008, 06:56 PM   #10 (permalink)
turbophil
Plug Whisperer
turbophil's Avatar
Images: 6
Originally Posted by TimMullen View Post
Actually, in the Celica, that oil does use a water (coolant) cooler. The hoses that are there is route to the coolant to the oil cooler. It is an effective way to warm up the oil, and then to cool it. But it adds to the radiator requirements since it must now handle the additional heat from the oil cooler. It also has to controlled by a thermostat since you want coolant to run about 195 degrees, and you want the oil to be 20 degrees or so higher.
Lotus actually removes the oil to water cooler and replaces it with the adapter to the oil cooler lines. That's why we have the U-tube. I don't know if the engine comes that way from Toyota or if Toyota uses the engine in another car without the cooler. The U-tube was a way to bypass the removed oil cooler, but has the problem of rubbing on the adapter that sticks out more than it would without it being there.
In the diagram below, we have the hoses in the red "circle" and the U-tube, but we don't have the oil/water heat exchanger - we have all the rest...
I'm not sure that's right about the Celica. From what I've read on the celica forum, they don't have that cooler either. The cooler is a TRD part...I may have read incorrectly and they may jsut be repalcing the stock cooler with a bigger TRD cooler...
Funny that Lotus used a U tube rather than just cutting the tube to about 4 inches long like I Mainelotus and I did and just connect the coolant rail directly to the block (which is all that 2 foot U tube does). Sure would clean up an already congested area... It just seems like an after thought...
-P
