Old 07-24-2008, 09:41 PM   #68 (permalink)
shay2nak
GGM ENFORCER
shay2nak's Avatar
i took all the parts to my lotus tech and he also agreed in grinding down the pegs. He's changed several of these filters in cup cars and he didn't recall ever seeing these pegs.
Also, I took my friend's air filter from his ES300 (same paper filter for cup car, Jack posted a pic of it) and it didn't fit within the adapter because of the pegs.
I also went to Pepboys to check the K&N filter, but they were out. TRD toyota dealer next!
Unless...I was thinking the the pegs raise the filter from the adapter. Why? because look at the filter from the cup side to the stock side. Yes, the filter is much larger, but the adapter shrinks it down to stock size. Also, if the adapter sits flush, it contacts the air filter preventing the air from going through. So I'm thinking these pegs raise the filter off of the adapter as to not contact the filter to allow the air to pass through. But, if that's the case, the pegs are not a good solution because the pressure exerted on the surround of the filter is concentrated on those points causing the filter to bend. Now if they had a raised narrow perimeter in line with the pegs that would be better.
'07 GG EXIGE S ** MY CAR ** VIDEO CLIPS!
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
