Originally Posted by apk919
The thickness of both roofs at the clam interface is no thicker than the rubber gaskets used to mate them to the clam... so it really doesn't seem that there would be any practical benefit to fettling the roof.
Without changing the external dimensions of the roof or the clam, I think I've gone about as far as possible be fettling alone. If I were designing the roof and the clam from scratch, I'd definitely make the "mohawk" cross section wider and/or taller.
Then, to my mind, if the roof is only allowing x amount of air to pass into the clam and there's no way to open up the roof any wider, it might flow more air WITHOUT the roof or with a roof sans a scoop. Then (correct me if I'm wrong) you could fettle the clam opening even larger because you wouldn't have to worry about a mating surface (to seal against a roof).
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
