Old 07-29-2008, 07:46 PM   #94 (permalink)
wildwhl
You bought a Locust?
wildwhl's Avatar
Originally Posted by Smoky View Post
Would love to see pics and a writeup of how the fans are located, installed, and wired-in to function. Are they always on when the car is running? Are they strapped to the i/c? Or elsewhere? Do the fans replace the function of the roof scoop, or supplement it?
I've seen several references to using fans on this forum but have never seen evidence of anyone actually doing it.
These are 2 of the 4 fans I'm using. They are Spal fans, 5.2" diameter if I recall correctly, 2 push and 2 pull (obviously, the pushers are inside the shroud). The controller is a Spal PWM 2 speed controller. The set points are end user adjustable/programmable. I tapped into the IAT sensor for an input. I have the low point set for ~100 degrees IAT (otherwise, sitting in the sun, well, anyway...) and the high point is not far above that, about 120 degrees. The switch up top turns the fans off - they are noisy and not always necessary/welcome.
I do not have any data logs to support my conclusion that they work. They do. It can and will be improved when I have full use of my tattered right arm again (titanium rocks!). The fans move a reasonable amount of air, and dropped IAT's about 30-40 degrees at the track.
My total expenditure was under $200 (purchased all from Ebay gradually over the winter) and they were very, very easy to install. 2 beers on a 6 beer scale.
If you're confused by the white stuff - that is dust. She hasn't been driven in about 2 months...
She's gone.
wildwhl is offline   Reply With Quote
