[Service #10 Drop-off] August 1, 2008 - 19,959 documented miles
I am not kidding.
The car has MIL/CEL (P0420) again, plus the exhaust was shooting out white particles/pieces (something is falling apart in there..., probably the cat.)
The car is now back in the service.
[Service #10 Pickup] August 12, 2008 - 19,961 documented miles*
This this we've replaced
fuel injectors and
coil packs, as well as the
Stage-II exhaust... (plus a little "upgrade"...)
All the services since new
[Warranty Service Items]
- ECU (replaced) - LBH
- catalyst/downpipe (replaced 2x) - LBH
- camshafts (replaced) - LBH
- O2 Sensors (replaced) - LBH
- fuel injectors and coil packs (replaced) - LBH
- exhaust (Stage-II cracks, replaced 3x) - SMC/LBH
- wiring Harnesses - LBH
- front/right turn-signal housing (replaced) - LBH
- A/C relay (replaced) - LBH
[Warranty Accessory/Part Items]
- soft-top bars (not supplied by dealer) - SMC
- blower motor resistor kit (update) - LBH
[Undocumented-Warranty Items]
- front/right turn-signal bulb (replaced) - LBH
- loose handbrake lever (repaired) - LBH
- passenger-side window making wind-noise (repaired) - LBH
[Non-Warranty Items]
- oil changes w/ Mobil Delvac Synthetic 5W40 (@ around 1,000mi, 7,000mi, 12,000mi) - SMC
- oil changes w/ Havoline Synthetic 5W40 (@ around 17,000mi) - LBH
- rear tires Yokohama ADVAN A048 (replaced @ around 12,000mi, nail in tire and wear) - NE
- rear tires Yokohama ADVAN A048 (replaced @ around 17,000mi, nails in both tires) - LBH
- front brake pads (replaced @ around 18,000mi) - LBH
- new front clam and clearbra (Star Shield) - SCC
(*LBH - Lotus Beverly Hills, *SMC - Symbolic Motor Cars, *NE - Newport European)
