Old 08-03-2008, 05:12 PM   #20 (permalink)
RoadDad
俺は道のお父様だ
RoadDad's Avatar
Originally Posted by foosh View Post
RoadDad suggested getting a Sears screw/bolt extractor kit which I did. It did a great job of removing one bolt.
In the process of removing the second bolt, the same extractor bit broke off inside. Once that happens, you are basically screwed because you can't easily drill through those hard extractor bits.
Didn't think that would happen.
As a "Hail-Mary" move, I cut a slot with a Dremel cutting wheel almost all the way through the bolt head per Brthtakr's suggestion, hammered a big screw driver into the slot, and attached vice-grips to the screw driver. Rather miraculously, it did back out the recalcitrant bolt, and I think the cutting and drilling may have finally freed the bolt.
Between driving to gather extractors, new bolts, figuring and fiddling, it was only a 7 hour oil change, of course, only 30 minutes was the actual oil change........LOL. Gotta love the Lotus.
"There are two things no man will admit he cannot do well: drive and make love." -- Stirling Moss
猫でも王様が見られる
Nunquam est ponenda pluralitas sine necessitate.
Pluralitas non est ponenda, nisi ubi est necessitas.
RoadDad is online now   Reply With Quote
