Old 08-05-2008, 07:08 AM   #144 (permalink)
Mag
Madness...
Mag's Avatar
Originally Posted by apk919 View Post
If I'm reading the schematic correctly, IAT is taken from the TMAF sensor, which would put it pre-SC. The temperature signal from the TMAP sensor (post-IC) is not used...
first off, I am just learning by seat of the pants so excuse me if the following is totally off. TMAF= temperature mass air flow?
If what you've pointed out is true:
1) why would TMAF have high correlation with RPM/Load etc? as you say the location is pre - SC.
2) How can this temperature be consistantly higher than that of the post SC/pre IC temps?
Searched around found this link. Pinout 18 TMAF - IAT ground and 31 TMAF - MAF ground. May be there are 2...
Forcedfed Dyno Plot
91 NSX, 3.2L ITB (in progress)
93 Supra TT
95 BCNR33 GTR, 2.8L TT
00 s2000, 2.2L
08 Exige S240
Mag is offline   Reply With Quote
