Originally Posted by apk919
I downloaded the manual and service notes back in February... it included a lot of '08 updates, including '08 schematics, launch control, new instrument panel, etc.
I wonder if there's still some way to make use of the temperature sensor part of the TMAP sensor on the intercooler. I noticed on Ocelot27's picture that it's actually tapped into the IC/intake manifold tube, where on my '07 its tapped into the intercooler itself... I'm assuming on your '08 it's tapped into the tube as well?
EDIT: I just realized that Ocelot27 has the RLS intercooler and tubes... so that's probably why his TMAP sensor is in a different location than stock
OK... are you sure of the wires on my pic and are you sure they aren't using this sensor for IAT - it makes absolutely no sense to measure IAT pre-compression?????? Charlie or Thomas HELP US!!!
I just want to know what wire to use to control the fans for my IC - there's conflicting info here and before I go cutting wires I'd like to know for sure what's what.
Also, you're right the RLS setup relocates the IAT sensor to the post-IC tube for those doing water/meth.
-john.
08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes...
"The early bird gets the worm, but the second mouse
gets the cheese." - Steven Wright
