Old 08-06-2008, 12:47 PM   #174 (permalink)
apk919
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Originally Posted by Mag View Post
Luckily not much work. The RLS IC I have is the WI one and the thermocouple probe fixture happened to be the same thread (retapped earlier).
apk919, if my data is correct, I'm afraid you are correct! Time for me to download that manual.
So I ran the data. Warning. Not going to like what you see.
Notice somthing grossly wrong here? Post IC is consistantly higher than Pre... accept when the car is at high speeds, where yellow line starts to drop off below the violet line. this was at 100mph. Got flow?
When I first connected the Post IC prob, car had had the probe in the IC during idling period, there after cooled off in the IC. Pulled it out and checked temps at 31, verified with infrared. Ambient 23C. After the log run, again pulled out the post IC prob out of the IC, and sure enough temps dropped from 60C to 33, which intuitively makes sense having been heated up by air and oil blow by.
Typhoon storm tonight so a bit cooler than last time. Windy. So interestingly, when the car was still or slow moving roof temps were on par with ambient, 27C versus 23C, but with the car jamming, temps rise to 30C therebouts.
Note: both probes used are same brand, both new, wire same length, run side by side, plugged into same device, which was calibrated just before the run.
Theories why it's so hot on outlet side... heat soak from SC is my guess. May be this is why the TMAP IAT is kept where it's at.
I guess I'm surprised that the outlet side of the IC is consistently hotter than the inlet side (except at high speeds)... even with no flow the IC must be radiating some heat? Why at time "0" is the post IC temp ~55C and the pre IC temp ~30C? Was the IC already heat soaked? It doesn't make sense that the charge is hotter after the IC than before... what's heating it up again? The engine compartment is not 55C, is it? I'm wondering if the probes are measuring the temperature of the metal surfaces, and not the temperature of the charged air?
OK, too many questions... I've got to take a little time to digest your data... it's certainly not what I expected to see!
EDIT: If you don't mind Mag, could you PM or email the session log to me? I'd love to see what's happening in those short bursts of boost...
EDIT2: You beat me to it... thanks!
