Old 08-06-2008, 01:26 PM   #177 (permalink)
apk919
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Originally Posted by Mag View Post
car had cooled down from previous idle, for about 2 hours. Time zero occured after cool down and about a minute during which the car was pulled out of the driveway and I could hit the log record button. Prior to engine start, the temps post IC was mid 30's. Which wouldn't be too suprising.
partially warmed up at time zero.
Wow, if the IC itself is at 55C after a minute or so of idling, that's bad.
I have measured the TMAp postion with an infrared temp gun after driving previous to tonight and it is at mid 50Cs. May be cos the TMAF IAT is much farther away with rubber airbox outlet/TB between it and the SC as opposed to the post IC temp probe location.
55C is 131F, which is where temps behind the IC went a minute or so after shutting down the engine during my data log. But while I was driving, even sitting still, the air in the engine compartment didn't exceed 115F (46C)...
I made sure the probe on the post IC side wasn't touching anything (bars/fins in core) and positioned somwhere in the center before the outlet coupling on IC.
Fixture is brass or copper I think and came as a kit with the probe. The pre IC side probe is exactly the same.
I'm just grasping for straws... I don't want to believe the IC is that hot...
yes please do. I have got to go to bed, hope to read on further analysis over breakfast
I'm going to load all this up on my laptop... I'm traveling later tonight, so I'll have something to keep me busy if the in-flight movie sucks...
