thanks for the feedback.
Also the OBD II IAT will read correctly, which in turn means that the OBD II readiness codes will set. I also took out the fan blip as it was a nice indication of a car running my tune but i think it caused people some concern, so i put different telltales in there instead, not that there aren't a shed load anyway.
On the first start, you'll get one error code of the P0601/0606 variety, its normal, meant to do that and will go away on its own, it won't cause any issues, but you willl need to do the 15 minute idle.
You might still get the really cold rough start, but without adding SAI there is little to do about it except wait 30 seconds before touching the throttle.
