Old 08-11-2008, 04:03 PM   #13 (permalink)
robains
2007 Exige S
robains's Avatar
Kris,
Made apt. with FF for Wednesday, dropping off Tuesday night. Hopefully you can find some time to provide any assistance to Casey if needed. Much appreciated!
Phil,
Lift was my exact issue at ButtonWillow, I needed very smooth throttle thru Riverside and was at a point where the car kept switch over and then under and then over and then under which made for a pretty wild ride thru that section of track. If I had more confidence in the rear end I probably could have managed the RPM better thru that section of track, but after my morning high speed off there, I was more cautions.
Casey was able to tune some of that out to some degree which made the experience considerably better thru Riverside section.
