Old 08-12-2008, 09:05 AM   #25 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Originally Posted by slaughtr View Post
Is it possible to stop the ECU from reverting to the lower cam at light throttle inputs? Why would it be like that in the first place, fuel economy?
Anyone?
I don't know anything about tuning, but from TPhil's description it sounds like you could set the TPS requirement to 0%, and that would make the cam switch purely RPM dependent regardless of throttle position.
Does that sound right TPhil?
edit: read further along the thread and see that up to the 12%-15% range would have pretty much the same result.
xtn
