The louvers are clip or snap on in the front but screwed on in the back. As in, in the trunk to get to the bolts. However if you can lift up the front of the louvers without messing anything up, there are two 4mm alien screws that hold the latch together. If you can unscrew these two the latch may (I’m not 100% on this, this is a guess) fall apart.
Of course this thread will need to be erased so as any would be thief cant do whatever works.
Don’t know how you will reach the latch maybe a ¼ in drive set with an alien tip.
