Old 08-18-2008, 08:16 AM   #24 (permalink)
apk919
No Acceptable Substitutes
apk919's Avatar
Images: 5
Originally Posted by slvr05elise View Post
So if you were to recommend a reasonably priced suspension upgrade for someone like me, what would you suggest. Do you think the track pack is better than the LSS and worth the additional money, and does the track pack require corner balancing, alignment etc. PS I have an 05 elise if that matters. Also, is the nitron sport pro suspension that much of a step above both of those options? At this time I dont' think I'm ready for the 46mm ohlins based on cost and adjustability.
The track pack doesn't need to be corner balanced, but it can be corner balanced. If you set the spring perches to the heights spec'd in the service manual, I don't see how that would be any different (in terms of corner balance) than putting on a set of non-height adjustable shocks. That said, I'd rather have the car corner balanced than not.
Whenever you change suspension pieces, you should do an alignment... castor/camber is not the issue, as that is pretty much determined by shim/spacer placement. But toe at all four wheels should be checked/reset (preferably with ballast in the car).
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD
Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam
apk919 is online now   Reply With Quote
