Originally Posted by slvr05elise
So if you were to recommend a reasonably priced suspension upgrade for someone like me, what would you suggest. Do you think the track pack is better than the LSS and worth the additional money, and does the track pack require corner balancing, alignment etc. PS I have an 05 elise if that matters. Also, is the nitron sport pro suspension that much of a step above both of those options? At this time I dont' think I'm ready for the 46mm ohlins based on cost and adjustability.
I had an '06 Exige with LSS which I upgraded to the 36mm Ohlins setup. I now have an '08 with track pack. The street ride with these is far better than the LSS and marginally better than the Ohlins. Unless you're a hardcore track junkie, I'd recommend the track pack single adjustable Bilsteins, nice compliant street ride and enough adjustibility for 8/10ths on the track. As for corner balancing, I found that just adjusting the ride height myself at home got it very close. Just make sure to check the alignment after you set the ride height.
Mike
