Rusty;
It is not likely that the cable is "stretched". It is a wound steel cable approximately 4-5mm in diameter. Not the kind of thing that is likely to stretch. Unless the threaded end is coming off the cable where it is joined. Theck for witness marks on the cable that would indicate that the threaded end has moved from its original position.
Have you checked the tie down point for the cable on the transaxle bellhousing? Bear in mind that the cable has 2 adjustment points under the car at the transaxle. From your earlier posts it would appear that you have been adjusting the clevis at the cable end where it attaches to the cross-gate arm on the transaxle. If you follow the cable forward you will see that the cable is anchored to the transaxle bellhousing near the starter motor. At this location the cable passes through a hole in the bellhousing and is anchored there by a pair of nuts that threat onto the end of the cable sleeve.
Are these nuts tight? If the cable is not securely anchored here you will give up travel in the shifter in the form of "slop" or "free play" due to not being fixed at this location. This mounting point determines the range of adjustment that is available at the clevis on the transaxle cross-gate arm. The shorter the amount of the threaded end of the cable sleeve that is exposed at the back end of the bellhousing mounting hole, the greater the range of travel. This could equate to a "stretch" like situation.
Regards,
Ron Schramm
'77 S1
'84 Turbo (x2)
