Old 08-19-2008, 08:56 AM   #1 (permalink)
Frank Amoroso
Frank Amoroso's Avatar
Help please: Airbags removed, now what about SRS Control Unit? See pics...
Greetings all,
I have removed my driver's side airbag by virtue of going with S111s Works Bell removable steering wheel hub. I've also disassembled the dash and removed the passenger side airbag while I was at it. See first pic below.
The Works Bell comes with a 2 ohm resistor to wire in-line that fools the SRS system from throwing a fault code. I assume I can just wire another 2 ohm resistor in place to fool the SRS system as it pertains to the passenger side airbag.
Here are my questions though: Can I also remove the SRS Unit (part number A121B0060F, see second pic below)? It would be great to remove this piece seeing as how I don't have any airbags to deploy anymore. If I remove this piece, will its absence throw an SRS fault code / light? If not, then I assume that I could remove it and I wouldn't need to wire in the aforementioned 2 ohm resistors?
THANKS!
Frank Amoroso
Whatever Press Vehicle(s) I'm driving this week
www.twitter.com/famoroso
Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it?
Frank Amoroso is offline   Reply With Quote
