Old 08-20-2008, 01:15 AM   #1 (permalink)
robains
2007 Exige S
robains's Avatar
Update pics on my S ...
Work in progress
The CF wing/splitter will arrive on Thursday, off to the track Friday evening, hopefully the car is more drivable/reliable now. Installing IQ3 oil temp, pressure, water temp sensors tomorrow (uses Vnet but wiring is ready for plug and play).
Wiring is done, dash brackets built - designed to be easy to remove when done with my track days and back on the street. Still need to powder coat brackets black.
Catch cans have arrived will install tomorrow.
Opening the roof inlet was easy. Wiring was a nightmare, but I wanted to do a quality job and heat wrapped all connections. Switches work great, Red for IQ3 dash, Green for AMB lap timer, Blue is spare.
The sprayer is for show, not hooked up to anything.
Car cleaned up nicely after my ButtonWillow off at 120 or so.
Goal is to keep the car as stock looking as possible, the IQ3 dash and lap timer removes with 2 bolts and simple disconnects leaving no trace it was there. Heck, I even used grommets for any wiring holes.
More updates later this week.
Rob.
