Originally Posted by shay2nak
for the offset, just use an offset calculator based on the stock wheel sizes. I can tell you the offset for a 9" wide rear wheel is around ~+43. Just do your homework and it's easy to find out. Not sure about 8" in the front...but again I can use an offset calc to find out. Prolly +30,31
Wheel Offset Calculator
smash factory has ET15 listed above for a 9.5" rear
That's way off from ET43. I'm pretty sure ET43 would be rubbing all over the suspension but what do I know, I don't even own one yet
I believe his setup with that low offset would be more flush with the outside edge, he might be stretching the tires some though. I wish he would just post the pics, I'd love to see that aggressive set up
It might be poking outside some though...I really think a 9" ET20 in the back would be more flush with the edge now that I did the numbers in the calculator.
