Phil u bum. I just finished mine this weekend too. Been working on it through 5 months of procrastination. lol
Glad you posted first though. Yours is way cooler looking than mine.
I'm using an Oregan Scien. ATC2K. Found a bracket from a previous install (amp bracket), modified the included mounting base, glued it to the bracket using high-temp metal/plastic adhesive (Loctite brand). Then drilled out holes for a u-bolt. Cut the u-bolt down and used wingnuts for easy removal. Attaches to the stock (or any other) harness bar. Any l-bracket can be used. Used edge trim (from McMaster Carr) to cover the u-bolt, but anything will work. I wanted something grippy. And then covered the bracket with velcro felt. This should prevent damage or scratching to the harness bar.
All can be made for about $5 of parts from Lowe's.
Not meant as a hijack, just a "me-too", since I snoozed and loozed. Yours is A+ though. I dig it a lot. We'll see if mine lasts through the bumps and potholes around here.
-Smoky
'07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1
