Old 08-27-2008, 05:04 AM   #18 (permalink)
reganfin
reganfin's Avatar
Originally Posted by Conan View Post
One suggestion: A piece of rubber or thick foam between the camera and the mount to help absorb vibration. It makes a BIG difference in the final video quality.
I have to disagree. I did some A/B tests when I built my mount and found that NOT using anything between the clamp and the harness bar made the image more stable. The padding actually increased the vibrations in the image. However, it does protect the surface of the harness bar from marring.
Unless you are using something like a gimble just mount the camera in as solid a manner as possible. Most video cameras have image stabilization that helps.
Whisky may not cure the common cold ……
but it fails more agreeably than most other things.
reganfin is offline   Reply With Quote
