Old 08-27-2008, 01:55 PM   #44 (permalink)
Kris from DRS
Dynamic Racing Solutions
Originally Posted by elise/europa View Post
I will also recommend the ARP studs. The torquing procedure is more like a stretching bolt procedure, reach that torque, and turn 1/4 turn, and another 1/4 turn. If you don't buy ARP stud, I think you should use new bolt since they are stretched.
Other than that, straight forward job.
The ARP studs we use are undercut and do not require stretch. Simply torque to 60 lbs/ft. I recommend doing this in 20 lbs/ft intervals (3 steps total) in the sequence, start in the center and work your way outside. Always use the ARP moly grease on both sides of the washer and on the threads for the nut, only use clean 30W oil on the threads into the block (hand tight the studs into the block).
Kris
Kris from DRS is offline   Reply With Quote
