Old 08-28-2008, 09:10 AM   #5 (permalink)
kverges
kverges's Avatar
The fact that the ECU is subtracting so much fuel trying to get to stoich makes me wonder if fuel pressure is too high or a fuel injector is stuck open. Given the fact that you have aftermarket (probably larger flow rate) injectors, then you probably need to tune the duty cycle with either a remapped or stand-alone ECU or piggyback to get back to stoich. That big a corrrection makes me worry that the ECU may change the overall injector size scalars and make the car go lean open loop, so I'd treat this as more than a nuisance.
kverges is offline   Reply With Quote
