Old 09-01-2008, 04:15 AM   #13 (permalink)
carbuff
Call Me LEO
carbuff's Avatar
Originally Posted by socal450 View Post
I am picking up a 90SE on tuesday and the exhaust is my first concern.I live in So.Cal. and they are strict on emissions,so I dont want to touch the cat,are you telling me that running a straight pipe(cat back)does not improve the sound.What size pipe do you reccomend(or muffler if any) Thanks......
There are several options for exhausts on a 90.
First of all, some of those years had a left-exit pipe and some had a right-exit. A 90 SE would use 2 1/2" pipe.
With some modification to the lower valence you could even install a dual exhaust (hint: the late-80s Camaro used a 2 1/2" single inlet with outlets on each side, look on the Magnaflow site previously referenced)
You will get a deeper sound with a cat-back resonator rather than a straight pipe, in my observation. For some reason, stainless systems have a deeper sound than mild steel, as well. (And they last a heckuva lot longer. Buy a Flowmaster at your own peril.)
For extra dollars you could even get a late V8 look with center-exit exhaust and the metal "Cheese-Grater". Viking Motorsports (Harry Applebee) sells these kits:
http://www.vikingmotorsports.com/parts%20001.jpg
Installed pic on his home page!
You would probably need a new lower valence though.
All of the above would make the sound louder and deeper than stock, which as I mentioned, were designed quiet because of European noise regs.
Atwell Haines
'88 Esprit
Succasunna, NJ USA
Lotus Enthusiast's Organization, NJ/NYC Area
www.LotusEnthusiasts.Org
carbuff is offline   Reply With Quote
