Old 09-07-2008, 07:35 PM   #39 (permalink)
apk919
No Acceptable Substitutes
apk919's Avatar
Originally Posted by FLuXeXigeS View Post
not sure if the Safecraft are DOT
but i like what you did to the seats...i am no means "skinny" so changing to more aggressive seats is out of the question, plus i drive my car on the street a lot
any tips on how you did the 5th/6th point hole in the seats would be greatly appreciated!
i got a good local interior guy that can reskin it
thanx
I cut a 1" x 6" slot in the bottom of the seats just in front of the metal crossmember... I used a Dremel with the metal cutting disk (the fiberglass is pretty thick under the seats, probably 3/16ths of an inch) to cut the slot. I only cut the fiberglass... not the leather. Then I brought it to Jim's Auto Upholstery (recommended by my local custom car audio dealer) to do the leather work. The Sector111 sys.6.pack is a pretty easy install...
Here's what the sys.6.pack looks like under the car... (the seats and sub belts are now bolted straight through the tub)
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD
Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam
